Did you read the card included with the pinion? What does it say on it?Question, I just got my Fire Team the other day. Can I run the optional Speed pinion for everyday use? or is it just for speed testing?
I actually made a run last nite maybe 80 degrees ambiant temp.. well got done with run figured hit lvc went to pull body off and remove lipo 6s. 6000 mah.. battery was very hot not normal and motor was hot enuf to fry an egg on it. Has stock heatsink stock motor fan.. and then I noticed my pinion was gone Mia.. ive never modified or removed anything off this car yet.. maybe 5 or 6 runs tbh .. do I want better fans yes.. but to me it was way hotter with stock everything then it should have been..Some people have heat issues with the stock pinion it is rather odd.
