Fireteam Fireteam + Outcast
Doesn't the FT have the handbrake module? The OC chassis is cramped as it is so will probably need to ditch it.
Other than that, central driveshafts and chassis braces, I think pretty much everything else should fit
You'll need a new front bumper if you use a Notorious or Outcast body. The Fireteam bumper and an Outcast body stick out the same distance in front of the chassis.
