Adamator
Hey all
Due to me being in uncharted territory here more than usual, I want to mention up front that not only I have only been into RC's in general for about 3 months now, accessing and working on a diff is even more new to me.
In doing some light maintenance on my Granite the other day, I had the motor mount and the wheels off. I was spinning the drive shafts on the wheels and I noticed the opposite side spinning was kind of sluggish on my back wheels. Figuring I can't avoid learning about the diffs and how to perform work on them forever, I thought I would open up my truck and pull out the rear diff to take a look at things.
Getting the diff with the drive shafts out was easy enough, but here is where my problems began.
Once I figured out I needed to put a screwdriver through the drift shaft in order to get the little screw off, I was able to get one drift shaft removed from the yoke. However, somehow, I stripped the screw on the other side and well... it ain't coming off.
So my first questions are to do with that stripped screw. Is there anything I can do, any technique I can try to get that screw off?
When I realized what had happened and there was nothing I could do at the moment, I decided to put everything back together as it was the best I could. However, I now have a new problem that appeared once I slid the motor mount back on. Now when I turn the rear wheels, everything is very stuff and almost wont even move. Furthermore, the driveshaft through the motor mount is no longer spinning at ALL.
I'm sorry to ask for help when I am probably not giving all the information, but what could I have possibly done to cause everything to seize up like that? I'm planning to open things back up to see if something seems obviously off but wanted to get some ideas of what might be going on first.
Back to the topic of the stripped screw. My initial thought was I would just buy a new diff from Jenny's RC. But then it hit me: they have the diff by itself. So I would potentially need a new diff, new yokes, and at least 1 new drift shaft all because I can't get that screw off. Unless of course I can make this diff work again, even though it's impossible for me to open it.
Thanks!
Edit: One more thing. Before I messed with my diffs, I had most recently taken my motor mount apart just to see how the insides were. Everything seemed fine so I put it back together with no alterations. The thing is, if I spin the spur gear, it seems to have quite a bit of resistance from the pinion gear on the motor itself. I can't for the life of me recall if it's always like that. Usually when I open it up, my focus is on my mesh and don't really spin it other than to make sure I have a good mesh. But I'm wondering if my problem could lie on the motor mount. Just wanted to mention that.
Thanks!
