What pinion did you run in the 6s & the Max6/1650 combo & what pinion would you run w that & a K6?I bought a Max 6/1650 Combo, back in May. Since then, it's been in a XMaxx, and a 6s Infraction. It ran strong, smooth and cool in both applications. It could find its' way into my new K6s EXB. I ran 6s in the XMaxx, and usually 4s in the Infraction, and they both ripped well. You can run 8s with the Max6, if you like
I want to say an 18, but I pulled the pinion off, when I put the Infraction back to stock. For the K6, I might start with ~15T, and check temps/performance.What pinion did you run in the 6s & the Max6/1650 combo & what pinion would you run w that & a K6?
I have a max6 that was only ran probably 15ish times and never a full session where the lipo was dead. Bought it for my typhon but pretty quickly after, got interested in speedruns so I bought a castle. You still looking for a max6???Hey, guys, so i'm looking to buy a new ESC for my Kraton 6s Currently it is all stock
And I would like to replace The motor with a spektrum 1250kv that I pulled out of my stock 8s and was thinking the Hobbywing Max6 Would Work Perfectly.View attachment 339547View attachment 339548
