Bennyboy2
- Granite
- Voltage
Installed these two HR parts today. Pretty easy install. Only a little confusing that they give extra screws and you wonder why(hope they were extra).
I noticed when I installed bearings and put the drive shaft along with fixing the hex back on that there was just a little bit of play between hex and block. There is at least a 1-1.5mm play. Wasn’t sure if anyone else noticed this when they installed. I am sure it is fine. The bearing gets pushed out with it ever so slightly. Unlike being seated pretty tightly in the stock plastic block these ten to just fit inside.
Just phishing for lil feed back from anyone else who has installed
