- Points
- 193
- Beadnell Northumberland Uk
- Kraton EXB
- Typhon 6s
Ok so I have a K6 EXB with as much M2C on as they make also HR bell crank , center diff cover and support. Vitavon diff housings etc. The only bit I still have problems with is outdrives snapping! I have my suspension set up same as Rich D and for the droop I’m using 5x4mm washers so the droop screw can’t back out, also using about 3-4mm of fuel tubing as bump stops but I’m still snapping out drives and it’s literally driving me nuts. Seen a few possible solutions, fuel tubing in cups to reduce movement, using Cvds in the rear( think Aldo Loyal did this) but what I’m really looking for is something like what M2C made for the Xmaxx out drives. That shim that sits around the cup to absorb pressure or something like a closed cup they just just made for the Traxarse
Anyone help me out here please?
