Hello fellow RCholics! I have this buried in my build thread, but I thought it worthy of sharing. I pre-ordered my Limitless, and I got it at release. Shortly after I had a daughter, so I didn’t get much time to play, so I’ve only driven it twice so far. I did a lot of studying aerodynamics to design my 3D parts during this time though. At some point Arrma changed the front bumper to have a more downward angle. Attached is a picture of the two bumpers. On the right is my original bumper, and in the left is the new style. If you zoom in you can clearly see the angle change.
However, even with this change the front splitter has an upward angle. This is in part due to the design of the chassis. I was able to place 4mm of spacers and achieve an almost level splitter angle. If I give myself a little bit of rake I should be able achieve a level splitter angle, and possibly even achieve an aerodynamically desirable downward angle.
I’ve seen posts on here about Limitless doing backflips (like this One), and also people not able to run without the front aero wings. This is due to the upward angle of the front splitter generating lift. Even if the splitter is level when you are sitting still, the front end lifts and the rear squats during acceleration, which would still cause the splitter to have an upward angle. Here’s a good Video that explains why you really want to achieve a downward angle with your splitter. I’ve also attached a picture of the splitter angle when the chassis is level with 4mm of spacing added.
On the right is the original, on the left is the new design.
With the 4mm of spacing added, you can see the front splitter only has a slight upward angle when the chassis is level.
