Big Rock Little update of my 12s arma nero
Maxikus
  1. BigRock 4x4
Made today shelf for esc
That's awesome.
I'm stretching my chassis currently and honestly didn't think about going to that extent with raw power. With the extra length and some space management, that might be able to be tucked back into the frame.
How does the drivetrain hold up? I'm possibly even looking at adding 24mm hexs along with some widening of the wheelbase as well, so drivetrain weaknesses knowledge would be great.
Im working on it yet, so once it will run, i guess alot of thing gonna start breaking. I just gonna. I was thinking to make streched frame from carbon fiber, but decide to give it a try with this configuration
That's awesome.
I just got done machining my first stretched chassis prototype and got extremely excited when I realized two 3s batteries line up perfectly down the chassis. Then I remembered your build and had to drop a line.
I plan on ditching the plastic battery contraption myself. I'll mill down a section on the tvp to restrict the batteries movement. Then straps or a plate can handle the rest.
I know you mentioned getting carbon fiber tvp's made, which is out of my realm for the moment. But if you need anything in the aluminum/steel area I would be happy to help your project along.
[/QUOTE]
Aftet some research, i decide to use for battery trays this ultrabox 307. Dimension of this boxes i think fitts my requirements
Thank you for offering some help, im trying to figure out what to do with a body, so i probably will need some of that
