You can download the manual on their websiteAny one know how to get the infraction v2 driving I toss out my manual by mistake now can’t get my infraction to drive do it have anything to do with the buttons and toggle switch on the remote. Please help.
Yes, I used a dx5c so I had to make a new model on the TX and open rx box to press bind button first but after that it should be the same process. With radio on, power up esc, pull throttle/ trigger to full, release, full reverse, release, then steering left full, release, then steer right full and release. This will calibrate the esc and should allow you to drive. Hope this helpsAny one know how to get the infraction v2 driving I toss out my manual by mistake now can’t get my infraction to drive do it have anything to do with the buttons and toggle switch on the remote. Please help.
Correction and I just found out how important this is... make sure you steer to the right first then left otherwise avc wil respond backwards. Glad I caught this before driving.Yes, I used a dx5c so I had to make a new model on the TX and open rx box to press bind button first but after that it should be the same process. With radio on, power up esc, pull throttle/ trigger to full, release, full reverse, release, then steering left full, release, then steer right full and release. This will calibrate the esc and should allow you to drive. Hope this helps
