Max 6 Female 6.5mm Gold Connectors
Deiglie
Anyone know where I can get a Female 6.5mm Gold Connector to Max6 esc?
Hobby shop should have them
How would you solder/rework those 6.5 Fem. bullets to the Potted ESC to begin with? A neat trick for sure. I see this happen frequently to the Max. Bullets popping out.:(
^^^^(y)(y)(y)(y):)
Seen that KT vid before.
@Rich Duperbash has also done this before, successfully on a Max 6.
Absolutely worth a try to save a $Max 6$.
From what I understand, the potted Fem. bullets do keep coming off that ESC due to high temps.
:cool:
^^^^(y)(y)(y)(y):)
:cool:
My problem is that I can not find these plugs to buy. That's what I need help with..
One female bullet is lost in battle.
You may have to improvise an aftermarket 6.5m female to work. I can see what you mean though. I have seen some guys even directly solder the wire to the ESC. I would not consider that an option personally. But some have done that with success.:cool:
Edit:
You may have better luck soldering a male 6.5 bullet (drilling a small hole at the bottom for soldering to the ESC board) Then convert the motor wire lead to female? Just some ideas.... :cool:
