Letting go of my v5 notorious build. Need some funds for my truck.
Build below:
Scorched parts:
Titanium shock towers
Front steering knuckles
Rear hubs
Titanium lower suspension pins
Steering bell crank ball bearing upgrade
Titanium steering stubs
Ball bearing Ackerman arm upgrade
Titanium motor mount screws
Titanium turnbuckle links
M2C parts:
3005 chassis
3035 rear shock tower brace
3480 ZRS shock caps (I have the rears removed one was leaking and I haven’t had a chance to re seal it but it’ll come with the truck)
3076 shock cap bushings
310854 diff gaskets
3030 steel hinge pins
3041 rear center brace
3047 front center brace
3065 Ackerman bar
3500 +5mm hexes
3616 hinge pin retainers and bumper mount
Misc:
Reefs Raw 500 servo
Aluminum servo mount
Aluminum rear suspension mount
Exb front bumper
Exb bell crank
3DRC bumper spring
Nhx dual 30mm fans
Titanium 4mm standoffs
Rpm wing mount
Modified Kraton cage
60k front/500k center/30k rear fluid
Brand new outcast body reinforced
As you can see I’ve sunk quite a bit of money into it, my next plan was to throw a Hobbywing or castle system into it but I’ve gone down the speed running rabbit hole so this thing just sits. I also have a crap ton of spare parts that will come with it. And the stock transmitter is included as well. I have a 6s zee lipo I suppose ill throw in too.
I would like to get $550 plus shipping for it (shouldn’t be be more than $25ish to ship in lower 48)
I’m located in Snohomish County, WA if someone would like to do a local pickup as well.
Build below:
Scorched parts:
Rear hubs
M2C parts:
3005 chassis
310854 diff gaskets
3065 Ackerman bar
3500 +5mm hexes
Misc:
Reefs Raw 500 servo
Exb front bumper
Exb bell crank
3DRC bumper spring
Nhx dual 30mm fans
Rpm wing mount
