Shannonclifford
New Member
I need to upgrade my infraction gears
Where can I buy some metal gears?
Thank you Hobbytown wants to charge me 175 dollars to put in plastic gearsAre you talking about the 3s Infraction? If so direct from Arrma.
You need 2 of each of these to do both the front and the rear.
https://www.arrma-rc.com/fr/product/cnc-metal-input-gear-13t-blx-3s/ARAC3711.html
https://www.arrma-rc.com/en/product/cnc-metal-crown-gear-37t-blx-3s/ARAC3710.html
https://www.arrma-rc.com/fr/product/composite-differential-case-blx-3s/ARAC4023.html
Cool I will order 2 of each. Are they hard to install? Hobbytown is way to expensive
Thank you all for you valuable informationI don't think they should be hard to install, you only need to take out like 4 or 5 screws to get to each diff, then each diff yolk has 4 screws in it. I've never assembled them either so I am not sure how easy they are to assemble but you just swap the internals out of your old one and put them in the new stuff. So many hobby stores are going to be more expensive than ordering parts online from like eBay or Jennys rc for sure.
What do they charge $150 an hour for labor?Thank you Hobbytown wants to charge me 175 dollars to put in plastic gears
It should not take 3 hours to replace both of the diffs and it's only $34 in parts. All I can think is they were trying to replace the entire diff assembly as those are $65 each.Not sure where he is located but the one near me charges 50 an hour with half hour minimum. Heck of a way to get people into and keep in the hobby. I can just see all the broken R/C cars sitting around because people can't work on them and don't want to pay for repair.
I just installed a complete set in my BRCC. You will need a 2.5 and 2mm hex driver as tools. Diff fluid of your choice too.Cool I will order 2 of each. Are they hard to install? Hobbytown is way to expensive
It isn’t difficult to accomplish. But then again, it all depends how mechanically inclined you are. It took me about 2 hours from beginning to end. But I’m super anal, so I tend to take longer than most.
Take. Your. Time. Most of all, have fun and learn from it
Here is a good tutorial I have saved.
If you’re referring to the 4s gears, I’ve read mixed reviews on those. Aren’t they cast?Or just buy complete metal diff assemblies from Jenny’s RC.
Ar ok. Didn't know they were different. My bad.If you’re referring to the 4s gears, I’ve read mixed reviews on those. Aren’t they cast?
If going to metal, I would suggest going with the CNC steel units (as you mentioned above).
