Fishtank
work the hardest when no one is watching
ArrmaForum Fan
Anyone try either one of these yet? Was thinking of trying one out.
I use the hot racing and the red aluminum Arrma ones. I saw those avd I’m always trying new things so I was thinking of trying the vitavon one.The main issue I see with those is neither of them have a steel sleeve where the diff output rides. The diff outputs can wear down the aluminum in the cup where they go through, I had this issue with the GPM units. The Arrma aluminum diff cups use a steel sleeve as do the Hot Racing 2 piece units.
You'd think they would have thought of thatThe main issue I see with those is neither of them have a steel sleeve where the diff output rides. The diff outputs can wear down the aluminum in the cup where they go through, I had this issue with the GPM units. The Arrma aluminum diff cups use a steel sleeve as do the Hot Racing 2 piece units.
I just like trying new stuff that's all. I have a bunch of diffs always looking for new stuff to try.I’m going to try the Vitavon outVitavon would be my bet. Otherwise stock arrma metal works great too.
Same!I just like trying new stuff that's all. I have a bunch of diffs always looking for new stuff to try.I’m going to try the Vitavon out View attachment 264160
+!The main issue I see with those is neither of them have a steel sleeve where the diff output rides. The diff outputs can wear down the aluminum in the cup where they go through, I had this issue with the GPM units. The Arrma aluminum diff cups use a steel sleeve as do the Hot Racing 2 piece units.
