New servo install
rudedogg79
I am having issues with the electronics after installing new servo. I have reset my esc and tried to redo factory settings, but it seems that I am not smarter than the system. Right now I reinstalled factory sevro and now my forward is reverse and reverse is not there. Looking for video tutorial or how to guide on how to undo what I screwed up.
Check the trim on the remote. If it's off by a bit, you can have things go screwy. When you plugged everything into the receiver, were you sure to have the plug set correctly? Black wire is to the outside on the receiver
Do you mean inside the waterproof box under the esc?
Yes he does. Make sure the servo and the esc leads are in the right position and the negative wire are in the proper orientation (ESC lead has a black negative wire. Your servo looks like the negative is brown).
Did you mess with any of the trims, end point settings, or throttle reversing switch (on the transmitter)? You reset your esc did you go through the throttle calibration programming?
You got any pics to assist with this? I tried looking for video, but no luck.
