Yup just flip the switch.I just got a Talion EXB. The steering is backwards. I know there is a switch on the transmitter to flip the steering. Just wondering if this is ok or if I should do something else to fix it.
thanks in advance!
You should reset your end points.Ok, no need to remind the transmitter? Just flip the switch and I’m good?
How do you set steering end points? I don’t see anyway in the manual. Just shows how to set throttle end points and rebind. Just to clarify, I don’t need to do anything with the steering reversed? It’s ok as is once I set the end points?
I think the Talion EXB comes with the DX3 and I don't know how to set the end points on that, but it should be a similar process to setting the throttle end points. Instead of using the throttle trigger you use the steering wheel.Once the steering is reversed and you set endpoints you should be fine.
What's the TX? A DX3? Here's a video on setting the endpoints. Just skip to about the 2 minute mark
