Outcast Outcast 6s EXB Motor fan
Reubydoobe
Reuby Doobe
  1. Mojave
  2. Notorious
  3. Outcast 6s
  4. Talion
  5. Typhon 6s
Does anyone have a link to a fan setup that goes on the new EXB Motor? It comes with the heatsinc but no fan to go with it. The rtr outcast 8s comes with a a fan I can't understand why this EXB doesn't 🤔
For laughs you could probably stack 3 fans on the heatsink like this:
F
F F
Each F is a fan*
It would be silly but I think it would work. Can't go wrong with more airflow.
I have been fighting heat issues alot lately and I have been trying some crazy ideas (and I'm going insane)
Yes, I do not recommend going to crazy fans for bashing (12V fans), they do not hold up well. Stacking makes them very inefficient.
You can only run 2-3 fans of this caliber on the normal BEC or you will get brownouts.
Gear down and slow down is the only answer, as much as it hurts. I stopped running due to summer heat.
I found one thanks to Eric at PDRC. Probably the best hobby shop in the world and definitely got the best pac man machine. Anyway there's one from horizon. Part No.ARA390300
I agree with @jkflow that fan is a waste of money, go with something like he left a link for. Not only will the aluminum housing save the fan and add life but it's also a lot higher RPM and better air flow.
i just ordered a rocket 35mm for my Talion EXB having been really happy with the 30mm versions on my 3S cars. However, unlike the 30mm versions, there's no cover avaialble for the 35mm size. Anyone got a link to one that will fit ?
Could try something like these:
https://www.amazon.com/GARDTEC-SC35-W1-Guard-35MM-Steel/dp/B0096QJSPC
I use something similar on my 30mm fans:
https://www.amazon.com/gp/product/B07DGWCZG8
They keep big stuff out, but still able to pick grass out more easily. The ones with smaller holes in them still let grass in, then it's a real pain picking it out without removing the fan.
Thanks so much. I also did some research yesterday and noticed these available on Amazon. Good to hear a positive report and your comment about grass is particularly helpful.
