I have a little torch that I got from Lowe’s for 20$Unscrew the grub/set screw in the side of the pinion. May have to use some heat to break free the loctite, can use a soldering iron and hold it on the screw itself for about 30+ seconds then should unscrew easier.
Thanks ed.13!!! Much appreciatedUnscrew the grub/set screw in the side of the pinion. May have to use some heat to break free the loctite, can use a soldering iron and hold it on the screw itself for about 30+ seconds then should unscrew easier.
