MiamiRC
Hey guys, lots of smart people here so I'm hoping someone has figured this out. I cannot get through a single pack of batteries in my XMaxx without the pinion coming loose, typically then destroying the spur gear. I have searched around the internet, watched the Youtubes, etc. and tried all of the following:
1. Hot Racing steel spur and Tekno pinion,. mod 1 with the 2.5mm grub screw. Blue then red loctite and I'm cranking the poop out of that screw with a MIP driver.
2. GPM steel spur and Arrma D pinion. This requires filing off a bit of the motor shaft so it slides on. The good thing about this approach is the pinion can't spin even if the grub screw comes loose because of the d hole in the pinion, but it still manages to just loosen and then vibrate until it falls off the end of the motor shaft. I'm red loctite all day at this point but makes no difference.
3. Replaced plastic motor mount with HR metal mount to increase rigidity.
I'm basically at the point I'm going to JB weld this motherf*fiddlesticker on and when the pinion fails just throw it out with the motor and get a HW combo, but hoping there might be something else worth trying before I go there. Anyone else have this issue that has it figured out? Thanks for your input.
