- 4x4-Mega
- Granite
- Kraton 6s
A few days ago the set screw on the main input shaft, front diff, backed out and my car wouldn't go. At the time I thought something in the front diff had broken. Turns out it was just a set screw.
Anyhow, I started to take it all apart when I discovered this screw was broken on the front of the gear box. I ordered a new stock gearbox, but I'm going to try and make the repair with this PlasticWeld and see how it holds up.
I cleaned everything up and used sand paper to scuff the area around the screw. I'll let it set up for a little bit and then back the screw out. Should be interesting. I'll clean it all up with a my Dremel when it's done and see what happens.
Anyone made a repair with this stuff??
