Yeah I think I have a spare wheely bar that I could chop about. I have a spare set of typhon wheels/tyres which I might also try.Yeah traction rolling happens very much so, when you run run wide long and heavier "Closed Wheel" bodies. A Typhon Buggy it is now.
High bite tires will always keep her on the edge of a traction roll. So you must consider that also.
But the chassis will stay SO Much cleaner now as a buggy. Just Watch your temps however. Might need a good fan solution there now. There is much less air flow inside a buggy body. One trade off. Keeping the rear wheelie bar, if possible, can still be an advantage.
Yeah the rest is all senton. How much wider do the typhon arms make it?Nice! Did you stick with the Senton arms?
I’ve already got a set of Typhon wheels and the hubs, so easy enough to swap over.Here's a pic of the Senton and Typhon head to head. Very little difference. I doubt swapping out arms would make a difference. Typhon has 17mm hubs compared to 14 mm on Senton however so you would need to swap out hubs to run Typhon tires if you choose.
