Vorteks Spektrum firma 100A smart esc.
Matt888
Does anyone know where I could get one of these fans and fan covers? I did a dodgy landing and I've damaged both parts. I've Googled everything I can think of but still can't find the parts.
You don't really need the shroud. I'm trying to remember if that fan is 30mm or 25mm but there are numerous options on Amazon and Ebay in that size. So you can always buy the appropriate sized fan and a fan grill and be just fine. I'll try to get some links here when I get home.
If you want here is the stock fan it is 25mm https://www.horizonhobby.com/product/firma-smart-85a-100a-120a-esc-replacement-fan/SPMXSEF5.html
If you want something a bit better this fan comes with a 2 pin JST connector, the stock fan uses a 3 pin JST connector, they are compatible but you have to plug the wires into the proper 2 pins on the esc or the receiver. You have a positive and a negative, on the esc the negative wire is towards the middle motor wire on the receiver the negative is always to the outside of the receiver https://www.ebay.com/itm/1662614055...Mx+W39hYB0icNnPoma9WmmMyJH|tkp:Bk9SR9aT7vGPYw
Fan cover https://www.ebay.com/itm/2652711283...r5R0Cj/6yPYQ8J3YwM8O6hC1Oh|tkp:Bk9SR_yhlPKPYw
A fancier fan cover https://www.ebay.com/itm/4042870116...KTb5CDg479VcXzgbFFr7Cy4oXq|tkp:Bk9SR_6hlPKPYw
Alternatively if you bought it new and still have the receipt Arrma does have a 2 year warranty, I am not sure if they would cover physical damage like that though. You can always try worst they can say is no.
