Granite Spray Lubricants
RcRookie
  2. Typhon 3s
Anyone have any spray lube they reccomend? After each run I clean. spray with wd40 to wash away old dirt and rust if any. Then I hit with gun oil in the bearings to keep then from rusting. However I don't want the wd40 to drop into the bearing or any other place that it isnt needed. And if I can keep parts lubed nicely without having to disassemble anything every run that would be awesome. Thanks for any help!!
These are what I use... the triflow come with a long straw to lube your bearings up without having to disassemble.
Are you washing it with water all the time? I don't run in the wet, I just blow mine off with an air compressor
Sometimes. Mainly I only try and spray the wheels and axles with water for any large amounts of dirt.
