OK, went out awhile ago, and ran my Kraton with it's new SRC road crusher tires and wheels. Very nice stuff, NO ballooning at all! However, while slowly driving out to the street, it went into a neutral? Motor spinning but no movement, forward or reverse. I assumed the pinion had come loose. Back in house, popped off the body, gave it some juice, and all was normal??? So I figured the pinion had come loose on the motor shaft, and had now slid back into position. Took a small screwdriver, and tried to pry the gear away from the motor. Tight, no movement. So I took it back out, and ran a hlaf pack through it, no problems. Still scratching head! 52 mph. Then grabbed my Nortorious, and commenced to bash the cwap out of it. Flipped it several times, several wheelies, etc. etc. then I heard a clicking noise when applying brake. Figured (ass-sumed) a diff was going out. Continued running hard, and no problems. After run, 54 mph, everything appears fine, no clicking, nothing abnormal. Maybe a stick or something got caught up in the works, but 2 strange incidents in a row.
