Saladfingerz
I noticed my front right tire on my vendetta is wobbling a little bit. The nut is tight and I can't figure out why it's like that. What can cause it and what fixes it?
Did you check the axle tightness in the drive shaft? Sometimes if they’re not all the way tight it can cause wheel wobble. It’s a good idea to run a 2mm up the wheel side of the drive shaft, remove the axles and locktite so the wheels don’t spin off. Not sure if it’s as big issue with a road car but it’s a definite to do item with a basher.I noticed my front right tire on my vendetta is wobbling a little bit. The nut is tight and I can't figure out why it's like that. What can cause it and what fixes it?
I'll have to take it apart a little bit to see. It may just be the wheel. It's got at least 4 or 5 batteries on it.Did you check the axle tightness in the drive shaft? Sometimes if they’re not all the way tight it can cause wheel wobble. It’s a good idea to run a 2mm up the wheel side of the drive shaft, remove the axles and locktite so the wheels don’t spin off. Not sure if it’s as big issue with a road car but it’s a definite to do item with a basher.
Make sure the bearings are seated and you haven’t cracked the hub carrier also. Sometimes they just develop a wobble from being used. Being all plastic the tolerances are not fantastic.
I took off the tires and checked the hub it looked fine no cracks and I tightened down all the screws that are connected to the hub and the hex. The drive shaft seemed alright and without the tires there doesn't look to be any visible wobble. And after I put the tires back on it seemed get rid of the majority of the wobble just by tightening some stuff. I think what's left of it is the tire itself.Did you check the axle tightness in the drive shaft? Sometimes if they’re not all the way tight it can cause wheel wobble. It’s a good idea to run a 2mm up the wheel side of the drive shaft, remove the axles and locktite so the wheels don’t spin off. Not sure if it’s as big issue with a road car but it’s a definite to do item with a basher.
Nice work! That’s a taste of what’s normal with these cars honestly. Maintaining means taking apart cleaning inspecting adjusting repairing…bash break repair repeat.I took off the tires and checked the hub it looked fine no cracks and I tightened down all the screws that are connected to the hub and the hex. The drive shaft seemed alright and without the tires there doesn't look to be any visible wobble. And after I put the tires back on it seemed get rid of the majority of the wobble just by tightening some stuff. I think what's left of it is the tire itself.
