Vorteks Tire Question
Jus10Time4Bashing
I am looking for a tire to replace the dboots Katar, But Here is the Kicker. I am not looking for Proline Badlands I have a set and I had to gear down my Truck. I want to run between 18t or my 20t pinion. I have the HR 17mm Hubs adapter and is give the truck just a tad bit wider stance. I reall like how it feels. I want to use a tire that has more grip with out having to change pinion or change the trucks geomertry. The truck preformes good with that size of tire. Any Suggestions will help.
Here are the specs for the KATAR
TECHNICAL INFORMATION:
Wheel bead diameter: 2.8" (72mm)
Width: 2.05" (52mm)
Wheel hex size: 14mm
Overall diameter: 4.53" (115mm)
