It's just humming the red dot responds when I press a button on the remote.Is the motor spinning?
The thing that has the fan on top is the thing that's running and operating (brain fart forgot the name of it). If I cut the car off and cut it back on it and accelerate it'll go for 3 secs and sput out and won't work.What's making the humming noise? If the motor is spinning but nothing else is moving then it's probably your slipper or pinion/spur gears. If the motor isn't spinning, but it's humming it sounds like it's shot or there's a loose connection somewhere.
Double check your battery, it sounds like low voltage cutout to me. Do you have a different battery you can try?The thing that has the fan on top is the thing that's running and operating (brain fart forgot the name of it). If I cut the car off and cut it back on it and accelerate it'll go for 3 secs and sput out and won't work.
Just noticed this light is blinking like crazy now but wasnt before. Yeah I have a hrb and lectron pro. Tried both same thing . Never had this issue so I'm wondering ?Double check your battery, it sounds like low voltage cutout to me. Do you have a different battery you can try?
Something wiggy is happening ? this thing is beeping now with a green lightI don't know what the different sequences of flashing lights mean on the speed controllers... Did you just charge the batteries? Check and make sure you actually charged them and didn't storage charge them.
I know my hobbywing will beep once per cell showing battery size - 2 beeps = 2 cell, 3=3. And green lights are always good, right? So... Sounds like it's all fixed!Blinking green now with this hrb battery and is beeping out loud never happen before? Any ideas?
Yeah I think the battery was just dead I put in my 6k mah and it's running good. False alarm, my front end is over with though lol camber issueI know my hobbywing will beep once per cell showing battery size - 2 beeps = 2 cell, 3=3. And green lights are always good, right? So... Sounds like it's all fixed!
Tried recharging the battery and I got a connection error so the battery is toast I guess. Thanks a lot for the help on this hot day!Yeah I think the battery was just dead I put in my 6k mah and it's running good. False alarm, my front end is over with though lol camber issue
No worries bro. Try and keep up with storage charging those batteries, it should help out with problems like that.Tried recharging the battery and I got a connection error so the battery is toast I guess. Thanks a lot for the help on this hot day!
