Typhon Typhon 3s running 4s outcast shocks
Mestizo_rc
Syracuse NY
  1. Kraton 8S
  3. Kraton EXB
  4. Notorious
  5. Outcast 6s
  6. Outcast 8s
  7. Outcast EXB
  8. Talion
  9. Talion EXB
  10. Typhon 3s
  11. Typhon 6s
  12. Typhon TLR
Some people say it cant be done but its worked for me. I do keep breaking c hub pins using rpm arms. Any input on upgraded steering blocks and c hubs?
haven't done anything other then remove all preload spacers. Might try the fuel line mod to shorten but she runs nicely both on Road and Off
Thanks! I'll have to mess around with it, but it's encouraging to know it's doable!
You did say this was with RPM arms though, correct? The extra mounting option for the shocks on those might help also.
Mounted in the more upright position on the rpm arms. It will extend the shock about 3mm if mounted in the outter position
