Typhon V4 low Vs high wing mount?
Evil-T
  1. Typhon 6s
I know the V4 comes with the low mount, now is this interchangeable with the arrma plastic or HR alloy high mount?
It is interchangeable. As the V3 came with the standard mount.
Note that the low mount have two mounting positions, and stock it comes on the lower setting. I think it looks much better on the higher spot. So if you want to raise the wing a bit, this is the simplest option.
