Flyr Rc
Ok what spur gear is for the 5mm bore 23t pinion gear
Ok I have a ezrun 3660 4000kv 3s and I have a 5mm bore pinion gear the stock spur don’t fit it won’t mess
You need to make sure it is a .8 mod.
Stock
thanks for the help guys I had the wrong pinion gear I needed a 17t
YesThanks a lot. That makes it a lot clearer. So a .8 and a 32 are the same.
They also have diffs and pinions and motor mount
