Rear dog bones will fit.Only the front cv shafts and rear dig bones. Stub axles and center driveshafts are different.
Front CVD drive shafts will fit.
Center drive shafts will fit. (The front center will fit as the rear center on the Talion. The rear center will fit as the front center on the Talion)
The axles will not fit due to the Talion hubs being smaller.
I suggest purchasing the Kraton 6S front and rear hubs so the axles won't go to waste. The hubs are a lot beefier and stronger. Plus it will widen the stance a little. I did the same thing to my Talion.
I have a set of GPM on my Outcast the cv shafts have been great but the stub axles were a bit disappointing, one was a super tight fit to get the hex pin in and I bent the other one, yes I bent the stub axle not the cv shaft. I've had them for a few years now and they have lasted longer than the stock ones, I have one that has a slight bend to it though.Thanks for the replies guys. What other options either then stock? Currently i have the aluminium hubs on my talion exb. GPM?
the stock are extremely durable IMHO, i wouldnt trade them for aluminium.Thanks for the replies guys. What other options either then stock? Currently i have the aluminium hubs on my talion exb. GPM?
Stock inner hub bearings are a top failure mode, rule one of owning a 6S to upgrade the inner bearing diameter with aluminum hubs. Plus the pillow balls will pull out of composite easily. If you’re putzing around on stock gearing, sure they’ll last a bit like anything RTR.the stock are extremely durable IMHO, i wouldnt trade them for aluminium.
Yes just use the stub axles you already have.Hi guys, Sorry if this topic is up here. Just wanna make sure i got the correct sets. Does the kraton 6S V5 complete driveshaft, axles and dogbones from JRC fit my Talion exb. Hopefully in time for BLACKFRIDAY discount at JRC. TIA
Yeah iirc the Fireteam uses the same hubs and stubs as the Talion.Thanks for all the info guys. From what i see going with Fireteam 6S BLX drive shaft kit from Jennysrc is the way to go. View attachment 336966
The only thing that won't fit is the front longer center drive shaft. Fireteam uses the Extra Long Wheel Base (XLWB).Thanks for all the info guys. From what i see going with Fireteam 6S BLX drive shaft kit from Jennysrc is the way to go. View attachment 336966
What he said ^ sorry I'm a bit out of it lately.The only thing that won't fit is the front longer center drive shaft. Fireteam uses the Extra Long Wheel Base (XLWB).
