- Statesville nc
- BigRock 4x4
- Kraton 6s
- Kraton 4s
- Outcast 6s
- Talion
- Typhon 3s
Just got this email
$10 more per pair. So $80 for the 3S and $100 for the 4S.Rip 100$ its the same concept of the 3s shafts but longer plastic sliders
The only way for the pins to pop out on the stock shafts is if your clutch is too tight or in a ackward landing the upgraded ones the whole shaft where the bearings sits and where the U join is located is metal the only plastic is the sliding hubsDo these solve the issue with the pins popping out of the u-joints? I assume so since these are CVD. I probably answered my own question but just want to confirm.
Also what means "on order" status at tower hobbies the metal diffs afe under that status$10 more per pair. So $80 for the 3S and $100 for the 4S.
Try beat me with stretched u join holes they never poped outView attachment 86135
Happened because i ran a tight clutch because i was noob decided to remplace the rear with new ones after 10-15 packs they have almost no slop vs the front who are sloppy af
You can donut just loosen your clutch you don't need a tigt clutch on an outcast 4s that thing will wheelie and do standing backflips even with a loose clutch watch kevin talbot he treats is outcast like a soccer ball
I will recommand bringing an allen keybor a 2mm driver its fairly essy to adjust the clutch on the field untightening it by 1/4 turn wont hurt really an outcast 4s to my eyes the 4s doesn't need upgraded driveshafts at all unless you are running crazy powerDa fack are your bearings okay it needs a lot of drag to cause that kind of damage i doubt you have 1.25turn from tight personally. I don't trust the ratings how i do it from now on i leave my clutch at 1.75 turn from tight with red threadlock so that the slipper doesn't crap on itself after i start tightenening and starts getting loose because i broke the bond.
I run it on open field and hear what noise it makes i run on 15t i ear a bit of whining of slippage but it wheelies on command and does exactly what i want it to do. If it wheelies too soon in the kraton case or wheelies when you don't want to wheelie or doesn't want to wheelie at all and all you hear is whining non stop are the signs of slipper set uncorrectly. I tight it each time by 0.20-0.15 turns on the field until i find the perfect tuning i use the sliper hub markings and my driver 2mm grub screw and i alight them with the slipper hub holes. I use permatex red threadlock maybe other threadlocks will completly weld the screw in place and you wont be able to tune it on the field
Arrma plastic thicc the traxxas ones just snap lol
The Hot Racing ones for the 3s models are like $160 bucks or so.Wholely wow, these things are a quarter the cost of the vehicle. I’ve only had my RC a couple weeks and hope the stock ones don’t break anytime soon lol.
