- Kraton 8S
- Kraton EXB
- Mojave
- Outcast 8s
- Outcast EXB
- Typhon 6s
My 8s Kraton is up for grabs. Not a whole lot of run time on this one. The original XLX2 did go up in flames so the shoo goo inside the body is slightly charred, and the electrical fire caused some corrosion rust. I cleaned most of it up and replaced quite a few screws. Currently it has a TP motor that will be replaced with a never used Hobbywing 1100kv. The max5 had an RCP switch mount and has two runs on it. I deanodized all the red parts on it. Currently it has the stock Copperhead wheels but they can be switched for a set of used Backflips, or a new set of the Duratrax Hatchet wheels. Located in Southern MN, not looking to ship. Going to start at a cool $1,000.
M2C chassis
M2C pillow ball retainers
M2C steering rack
M2C esc mount
Max5 with 1100kv hw motor
Raminator Servo
5mm sway bars
Arrma metal front and rear diff housings
Diffs filled 1million front, ear plugs center, 500k rear
Arrma stone guards
3drc front bumper spring
Carbon fiber wrapped tower to tower braces
Uninstalled M2C 7mm front shock kit
30wt shock oil in the front, 35wt in the rear
PPS motor slide
Geared 30/47
M2C chassis
M2C steering rack
M2C esc mount
Raminator Servo
5mm sway bars
Arrma stone guards
PPS motor slide
Geared 30/47
