Iv just done it..thank you..i nearly forgot..???????Make sure to remove that rubber seal, so you don’t make yourself a bomb!! ?
Im going to jazz the box up abit...probably add some of the decals that came with my kraton 8sMake sure to remove that rubber seal, so you don’t make yourself a bomb!! ?
Omg..????...next pay day now..im getting another set..£100 each..this is one expensive hobby but worth it...View attachment 83460You need more batteries ???
That's exactly what i did after searching for the gasket in the bin.????...it kept opening up and didn't close properly...i knew they was a fix for this.???Take the rubber seal, and cut off one of the short sides. Re-install the short piece on the latch end of the lid. The latch needs a bit of 'spring' for it to work right, and the gasket is that spring.?
