- MN
- BigRock 4x4
- Granite
- Granite Grom
- Granite Mega
- Kraton 6s
- Typhon 3s
- Typhon Mega
Might be boring to some of you but, I'm having fun. Plenty of things to do in the future. Call it a work in progress. So far.....
Got the 57T .08 mod slipper, casing and heavier motor plate. Installed the bearing on the driveshaft. Got a Spektrum system pulled from a Kraton 4s. 120 Amp ESC with 2400KV motor. Came with a 13T pinion. Put a 15T on it. Lame. Put an 18T on it. That woke it up but, did not keep up to my buddy's stock Big Rock. Made several speed passes in the street and ran it hard through an uncut field until battery cutoff. It was 80F and the ESC and motor were barely even warm to the touch.
Think there's more in it. Going to try a 20T pinion. Oh, and I'm only running it on 3s. 5200 Zee's. I don't feel like tearing out the drive train every other run. Just want something to keep up to the other 3s vehicles. With enough wheel speed to be able to control the front end on the new found track and maybe some light bashing. I'm turning the Granite into the "do crazy things with" vehicle.
