RCcarsandstuff
The car is a Senton mega 4x4, I've installed a hobby wing 3660SL 3150KV G2 and 10BL120 G2 ESC, the motor is mounted in a Senton 3s BLX motor mount. 0.8 mod 18 tooth pinion gear, and Senton 3s BLX spur gear 57 tooth slipper clutch. I have added these larger 5" tires ( AllinRC 1/10 Scale RC Truck Tires and Wheels Pre-Glued with Aluminum 12mm Wheel Hex Nuts Compatible with 1/10 Arrma Granite Big Rock Vorteks Monster Truck (4 Pack) https://www.amazon.com/dp/B0BBMVF8MX )
I currently run it on 2S and it works well, however it cogs when starting at an uphill or sometimes when just starting out.
I thought maybe being 3150kv and 18tooth 0.8 mod it might work but I think I might go down to 13T? I did buy a pinion kit that goes from 13T-17T so I can change them but I think the 13T might just be best for no cogging and quick acceleration but it should still have a bit of top end?
I will like to eventually go up to 3s and 4s possibly (the ESC and motor says it can, however I'm not sure if the Senton drivetrain can?).
