Limitless Anyone have Photos of their custom limitless!
TCRC granite
Hi i was trying to get some limitless ideas and that maybe some of y'all would be interested in sharing a photo of your custom limitless. And I'm also curious on motor and esc. Thank you!
Has anyone tried carbon fiber body?
If you post in the AF "Speed Demon" threads, you might get better results.;)
These guys have some of the nicest builds.
The question is are you the type to make your own parts or are you the type that will be purchasing the parts and bolting this car together?
No matter the answer the chassis, axles, trident center shaft setup, motor mount, and some other odds and ends should likely come from Scorched UK.
https://scorchedparts.co.uk/collections/arrma-limitless
Perfect pass springs are a good purchase.
You should expect to spend no less than $2,000 on a build of this caliber.
Standards are the XLX2 ESC setup with QS8 connectors. GRP tires for getting started and once you hit 140 mph swap to BSR xx pink foams and finally to purple once you hit 160+ mph.
A quality long-range radio setup (signal booster is needed for speeds over 140 mph)
Most everyone uses the TP Power 4070 or 4080 motors. The 56 and 58mm options exist but come with some extra headache that is not worth the hassle in my opinion.
Some inspiration for you from years ago (2020) when I built the world's first stretched limitless and full carbon body.
I run a Castle Creations 1721 2400kv Brushless Motor with a Castle Creations Xlx2 esc on 8s(dual 4s Batteries) but unless your looking for straight up speed runs I don't reccomend my setup the motor voids any warranty for any esc as soon as you plug the motor wires into the esc due to its insane power and capabilites the radio i use is the Radiolink rc8x with a rc7fg or rc8fg reciever both have dual antennas and 1600 feet or 600 meters of range and i can personally attest to that range I wrecked this one at about 150mph with GRP tires that are still good as well btw but working on my second Limitless v2 Build now using same electronics from 1st build I hope that helps brother
This is the latest
