Mike-NLD
By the looks of it, Arrma prepared the front centerbrace mount for future Typhon use..
As you can see.. Theres a hole in the top of the mount.. Wich exactly fits a body post.. Theres even a hole to put a through a screw to keep the bodypost in place.. (The way the rear Noto and OC bodyposts sit in their mount)
As you can see i tried to make it work..
Front of the body needs a slightly more forward hole to fit the new bodypost.. Body will sit a little higher, due to the centerbracemount now underneath..
Only problem to make it work was, i somehow couldnt get the wingmount to fit.. The rear centerbrace mount compared to the plastic part wich holds wingmount look to be same.. But wingmount wouldnt fall in the notches..
Anybody who tried and succeeded?
