Christian’s RC’s YT!
if you have any questions let me know it would probably be better if you did this with a arrma 6s diff..
idk what’s next i just needed this rc to run so that’s what i didInteresting solutions, good job keeping it going with () Traxxas parts.
What's next?
my bad i need to fix my spellingWho is Senator Diff?
The Senator representing the state of Arrma! Everyone should know who represents them in Washington.Who is Senator Diff?
You can use the 4s Mojave's center diffi wish someone would come out with a center diff for the 3s it would handle so much better.
doesn't that make the battery bay shorter? you have to use the mojave motor mount/diff case too correct?You can use the 4s Mojave's center diff
It does exist with the 4s line.i wish someone would come out with a center diff for the 3s it would handle so much better.
there is only enough room for normal lipos in the senton unless you drill new holes and move the battery bay forward.Yes but it’s still a decent space for normal lipos
Then what’s the problem? Do you have big lipos?there is only enough room for normal lipos in the senton unless you drill new holes and move the battery bay forward.
big lipos have nothing to do with it. when you use the kraton 4s motor housing and center diff in a senton 3s it makes the battery bay shorter so batteries no longer fit unless you mod it.Then what’s the problem? Do you have big lipos?
Here you can see it’s almost flush with the battery spacerbig lipos have nothing to do with it. when you use the kraton 4s motor housing and center diff in a senton 3s it makes the battery bay shorter so batteries no longer fit unless you mod it.
If it’s such a problem to fit a normal lipo you can just take out the the front spacerits not flush. it looks like almost a 1/4 inch sticking out.
