samintrepid
- BigRock 4x4
Hello Guy, I have install the HobbyStar 3670 3050kv in my Typhon 3s because the factory motor overheat with 26/57 gearing.
Lil more torque, it's a longer can run a little cooler and do a little better with gearing up a little.
Very cool. I haven't had any problems with the stock motor for my uses (granite is basically my skate park car), but if I ever have issues with needing a bit more kick then I'll get one of these!
How does the Castle 1415 2400kv motor compare to this Hobby Star motor? I'm considering buying one.
I wouldn't go anywhere near that low of a KV motor on the 3s line. With all the driveshafts and diff case gearing being composite instead of metal that low of a kv is just gona destroy everything.
We are a lucky guy Stitched because it back order everywereLooking good fella. Have that same Hobbystar going in my Big Rock this week
It for running 4s in the futur and the other reason it because the stock motor overheat with the 26t pinion gear.I think Rich Duperbash put this in his Senton 3s. What would this get you vs. the stock motor in a granite?
I have put the castle 2400kv in my stampede 4x4 and the difference it the kv 2400 vs 3050 and the other is the castle run with max 4s, the hobbyStar able to run 5sHow does the Castle 1415 2400kv motor compare to this Hobby Star motor? I'm considering buying one.
Honestly it's not as torquey and I thought it would be. I'm running an 18t pinion. Temps seem ok though.I've got the Hobbystar 3670 3050kv on the way. How are you guys liking them still?
Its bound to be better than 3650 cans and the 2 pole 10.5t I tried to run.Honestly it's not as torquey and I thought it would be. I'm running an 18t pinion. Temps seem ok though.
No doubt!Its bound to be better than 3650 cans and the 2 pole 10.5t I tried to run.
Hi, I upgraded my granite mega with blx100 and hobbystar 3670 motor. The original arrma blx motor heat sink fit for the hobbystar motor?Hello Guy, I have install the HobbyStar 3670 3050kv in my Typhon 3s because the factory motor overheat with 26/57 gearing.
Yes it fits. I have the same set up.Hi, I upgraded my granite mega with blx100 and hobbystar 3670 motor. The original arrma blx motor heat sink fit for the hobbystar motor?
