So I finally got a 3s lipo and the power is great in my Typhon. What I'm noticing though is that my SMC 5400 true spec premium pack takes a lot longer to balance than my old 5200 mAh 50C lectron pro 2S did. It "switches over" to balancing at about 43 minutes coming from storage voltage (3.8v/cell) and then balances until about 69 minutes. At the start of balancing the cells almost always read 4.16/4.18/4.20 with that last cell being the limiting factor as my charger has 500mA balancing drain per cell. Balanced voltages read 4.19/4.21/4.19 at completion on the charger or 4.17/4.19/4.18 on my digital multimeter.
Does this seem normal? I only ask because my 2s, which is almost a year old, only ever takes 10-15 minutes to balance charge. I'm tempted to charge at above 1C as 25 minutes of balancing really adds a lot of time to the charge.
My charger is a Ultrapower UP100AC Plus by the way. Part of it might also be that my Lectron Pro pack seems to only take around 2000 mAh from storage voltage where as the SMC takes around 3400 mAh. I do notice that the SMC pack has much better run time as well.
