New December 2020 Kraton 8S:
(see my initial thoughts and observations post to put this question in perspective)
The bending of the baseplate seems to be a common thing, at least on the first 8S’s sold – no wonder since you’ve got 2 heavy battery packs, motor, etc… sitting on it. So, trying to strike a balance between complexity, weight, and cost, I was thinking of attaching two pieces of ¼” square steel rod to the underside (see picture of a draft plan). I’d countersink bolts through the compartment side and tap threads for the bolts into the steel rod. I’d shave down at an angle the ends of the rods to prevent them from catching on anything.
What are your thoughts on that?
Thanks!
Thanks!
