Jluther@becoinc
- Senton 6s
- Talion
My Outcast keeps bending the front upper Tower to Tower brace. Does anyone make an upgrade? The chassis don’t bend just this top brace
Make your own like I did.use aluminum double bar ,stronger than what's out there..and looks better in my opinion.My Outcast keeps bending the front upper Tower to Tower brace. Does anyone make an upgrade? The chassis don’t bend just this top brace
Where did you get the material from?Make your own like I did.use aluminum double bar ,stronger than what's out there..and looks better in my opinion.
Why buy something that you see on every rig . customize and modify
I bought everything at a local hardware store.im sure you can find everything you need at Lowe's or home depot.not expensive at all.i had to double up on the bars because they don't make one solid bar ,but two is just fine .you can reinforce them but using one bolt in the center or one on each end and middle.use nylon nutsWhere did you get the material from?
I’m ordering the carbon fiber now. Thanks a lot. Will 10x6x420 fit right over the original bar? If it works for you it works for me .most people throw a CF tube over the brace with some heat shrink on the ends and call it a day as it works really well.
https://www.amazon.com/gp/product/B08ZSZ8V6Y/
10x6x420mm IIRC
10x6x420mm IIRC
I was just playing around with parts and realized that the 5mm hinge pins will fit perfectly inside the center braces. I’m just wondering how much strength that would add if they were cut to the proper length.
