Nicholas yambao
Biggest 4s motor that can safely fit into the big rock. I have the metal crown and input gears for the diff so I know it handle some juice.
Wow! Nice rig man. That's what I'm kinda working towards. I've had my eye on the hobbywing 2600kv. Did that fit directly to the motor mount? Or did you have to modify it?
You have run outa room. I wish somebody would come out with a smaller spur for them.need to swap to mod1 gearingThank you! I have the adjustable mesh mount from HR as well as another motor set up with the adjustable mesh mount from Arrma. I just changed pinions Friday and am now running 27t while keeping the other rig at 25t. The 27t required a slight bit of tooling to get the mesh just right. Everything else bolted up nicely on the stock mount without modification.
