5AFE CRACKER
- Kraton 6s
My guess is neon orange for the 6s line I've seen it on the 8s but not really neon color
My guess, they streamline production and only make one body, might even be a new color. 'Plum crazy' here we come! ?
With the way stock/parts have been lately I’d buy a brand new truck with no body included, I’d buy one with a pink and rainbow unicorn body, as long as they actually have stock.Hello,
I just want to confirm with you guys the information that I received from a shop that I contacted in Europe asking for the blue Kraton 6S V4. I received their reply saying that:
"You asked to be notified when the product ARRMA Kraton 6S 4WD BLX Monster Truck Blue/Black 1:8 RTR becomes available again. Unfortunately, the product is permanently out of stock and will no longer be available for sale. Contact us if you’d like us to help you find a replacement for the out-of-stock product. "
They have the red available but no blues anymore :/. In the meanwhile I was able to order the last one in stock from another shop .
But its weird for me, having one colour and not the other. I think that here in Europe they all order their Arrma stocks from European HorizonHobby.
Have you heard about this?
Thanks
Where did you get that car stand? That's cool!
https://www.ebay.com/itm/133364682322Where did you get that car stand? That's cool!
I will also order the M2C chassis and center braces as soon as they are available. Expensive upgrades, but I think it will save me alot of issues
Thank you for the hints FlipSide . I think that when Im done with the upgrades it will almost cost the same as the car :/, bt I already knew that this was an expensive hobby . The most expensive will be the M2C parts but according to what I have read I think it will worth it . I was thinking in upgrading the servo to a 25Kg do you gys thik its enough or its better a 35kg. I will try some cheap ones at first, I read some good things about these ones, the DSServo3225 and DSServo3235While you're at it, you could consider a rear shock tower and rear shock tower brace if you have the money.
The stock rear shock tower bends really easily on the Kraton. If you're lucky, you can bend it back, but it's a pain to remove and re-install.
The rear shock tower brace is not required with the shock tower, but it is a very good upgrade that protects the bulkhead.
25kg will be fine.
Yes, I am getting there as well with the upgrades. So far, I have a DX5C Tx, Savox 1210SG servo, GKA Ackerman plate, servo mount and chassis braces, and M2C chassis, rear shock tower and shock tower braces. I also have a few other bits from M2C that I haven't installed yet. I'll probably wait until the rest breaks before I upgrade...that is unless I get a PPS motor mount for the bling factor (and totally awesome design), but the V4 motor mount is fine IMO.
Not all upgrades are expensive however. One of the best upgrade you can make on the V4 Kraton is to add two 1/2" c-clips to the V4 servo saver. It costs a total about 2$ and completely changes the steering of the truck.
Where can you get these 1/2” c clips??
Great! I’m going to try this, since I’ve been underwhelmed with the steering performance. Doesn’t seem to have turning strength at speed, even with a strong servo. Hope this helps!! I sorta wish they kept the v3 adjustable design. And the whole steering post design is actually pretty horrible.Home Depot or any places like that. If you need a tutorial, check out the East Tactics youtube channel. He has a nice video explaining how to do it. I strongly recommend using c-clip pliers to put them on. Once the c-clip are on the hexagonal part at the bottom of the servo saver, you use a socket to push it all the way so that it sits nicely between the servo saver spring and the aluminum hex.
The vid from East TacticsGreat! I’m going to try this, since I’ve been underwhelmed with the steering performance. Doesn’t seem to have turning strength at speed, even with a strong servo. Hope this helps!! I sorta wish they kept the v3 adjustable design. And the whole steering post design is actually pretty horrible.
Nice idea with teh clips25kg will be fine.
