Boondock115
The 85a esc is fine i put 4 3s 80c 6000mah batteries in it over the last 2 days and it's had more than enough power the entire time. Thanks for your opinion though, I was just sharing what happened in my own personal experience
Copy that, well now I know, thanks for sharing your knowledge fellas, apparently my mistake for trusting my local rc shop owner.+1
85amp is TOO small. Yes. LHS has no clue. That is why. They are spending/taking your $$ unwisely. Or just slamming you with what they have in stock perhaps?? You will end up disappointed and buying twice over. Be careful.
Need a 100amp minimum, at the very least. 120amp ideal for 3s running.
@Kla912000 is 100% dead on correct. I would follow his lead on this. Common knowledge here. If you look closely at the 85 amp specs, it is just not the correct ESC. Albeit a cheaper alternative. Sure it may work for you. For while. Just not the correct match for that rig. Arrma specs 100amp for a reason on this 4x4 chassis platform. No getting a round this fact. Being a 4x4 drivetrain and heavier than average for most 1/10 scale rigs. Requires much torque. 85 amps would not suffice efficiently enough.
Figure only running 2s with that 85amp esc. No more. 3s is pushing it IMHO.
My spin.
