FerrariBLX
As stated in the subject line: What car and/or truck bodies are there available to fit the typhon 3S chassis?
You would likely have to change the mounts to the ones used on the Kraton 4s or Big Rock. Same chassis, different mount location. That would open the door to more options.As stated in the subject line: What car and/or truck bodies are there available to fit the typhon 3S chassis?
Do you have the link to iti know that delta plastik makes some killer bodies that will fit the typhon like a porsche 911 body or a shelby daytona coupe but it requires senton body posts
It’s a fairly old thread so may not get a response. What 3s car are you wanting to put the proline body on?Do you have the link to it
I was thinking about putting the pro line Chevy Silverado on my 3s
https://www.prolineracing.com/produ...l-boss-clear-body-short-course/PRO351200.html
Oh didn't realize I didn't say, typhonIt’s a fairly old thread so may not get a response. What 3s car are you wanting to put the proline body on?
I'm in the process of fitting the porsche body to my typhon. Senton mounts aren't an option because they only mount to the senton diff housing. Using limitless/infraction mounts which seem to work decent. 2+ inches of free space on the sides and almost 4 in the back. Using an infraction front splitter so the body isn't the 1st thing to hit. Working on what to use to fill the gaps. Mine is using limitless shock towers and springs, so overall lower and doesn't need the two bumps in the hood.They have it at my local shop so gonna see if it looks good down there
I have a Typhon 3S that I truggyfied with 3.8 wheels and was wondering if the Bronco body would fit ?i know that delta plastik makes some killer bodies that will fit the typhon like a porsche 911 body or a shelby daytona coupe but it requires senton body posts
Did you end up getting that truck body? How did it work out on your Typhon 3S?Do you have the link to it
