It looksNiiiiiice. Is he still selling them? I need a set. Do you have a link?
ok I finally got round to install it - it you can set it to:Thats what i try to avoid it has flashing mode and on off mode
Yes but i only want on and off there is a few on amazon but idk if they are the right onesok I finally got round to install it - it you can set it to:
1) PERM OFF
2) PERM ON
3) Flashing ON/OFF and it cycles through 3 different interval cycles and brightness cycles
works fine for me
have a look here - just posted a video https://www.arrmaforum.com/threads/r4nd0ms-kraton-8s-kratonstein-build-log.21079/#post-291240Yes but i only want on and off there is a few on amazon but idk if they are the right ones
I switch On / OFF / ON ...... OFF ... in the video
the Krarton 8S has slots front and rear so there is plenty of space especially as only the receiver antenna is actually ending up leaving the box - I know on my Notorious and Granite this is already quite fiddly with ESC and antenna coming out however you can always cut in and then seal with shoegoo shoudl work just fine - take the wires out of the connector, cut into the box enough so you can get the cable through and then seal from inside and outside with shoegooNice i have tail lights glued with shoegoe under my wing but i have nothing for the front mainly because my wire exit for my radiobox is pretty much full and there is no place to put leds in the front who would be protected and look good at the same time
I already cuted the silicone seal for the wires menaged to squeeze my led rear light on going to try figure something out for the kraton headlightsthe Krarton 8S has slots front and rear so there is plenty of space especially as only the receiver antenna is actually ending up leaving the box - I know on my Notorious and Granite this is already quite fiddly with ESC and antenna coming out however you can always cut in and then seal with shoegoo shoudl work just fine - take the wires out of the connector, cut into the box enough so you can get the cable through and then seal from inside and outside with shoegoo
