Camservos7
Just unboxed my arrma 4x4 kraton 4s . Turn everything on . I can turn the wheels . But no throttle at all . And the esc is beeping twice with a red light . Pls help
I'll look again . Doesn't say to do any of thatread the instruction manual and do a calibration of the Transmitter. That might help.
Ok I do see it Saya throttle setup but it's so confusing or I'm dumb. As soon as I turn the esc on it blinks red twice .read the instruction manual and do a calibration of the Transmitter. That might help.
I'll try that . And yes I have slt3I do not have a 4s but i have a 6s. i do not know if they are the same. it gives instructions for slt3 radio. is that what you have? if so then connect battery, power on esc. press button on receiver 3 times within 1.5 seconds. set trims to center on transmitter then power on transmitter. this is for 3 channel sr315 receiver. make sure you have the wheels off the ground when you do this. i set mine on a cardboard box to do it.
Didn't do anything. Sucks Asa was looking forward to this thingI'll try that . And yes I have slt3
Thanks I'll try that
Can I add to this post?
My granite brushless has the fast flashing red led. The car is my kids, it’s ran great for two weeks, and today he plugged a fresh battery in, no control of any kind, the esc will not respond to the learn mode or bind settings at all. Any suggestions?
Ok, Iv examined the white wire and all wiresCheck the wire for the esc going into the receiver box to see if the white wire got pinched or severed anywhere between the esc and the receiver. I've had this happen before, had the esc wire pinched between the rear of the chassis and the shock tower took me forever to figure out why it wouldn't do anything but flash the red led and I could not get it to go into program mode either.
