Clan-of-Nowina
Bought the motor and ECS for another project and bought this tonight used. Locally bought used. Came with everything and 3 batteries. May have spent a bit much, $125, but after wiping it down, it does look like it was used only a few times. With minimum skidding time on the body shell. Should I do it? I have the manual and it gives the part numbers to upgrade it. Has required parts and not required parts. Use factory parts or aftermarket? Can i go as far as adding a front diff? Well it’s late and i will look it over good tomorrow. Will also receive my new charger and might be able to hook up the deans connectors to it. Than i could a least blast it around as is to see if anything is wrong with it. Will update as i go.
