vorteks maniac
- Vorteks
I’m looking at these
I drive mostly on Asphalt but sometimes I drive off-road (mostly dirt not grass) I’m looking at these right now but I want cheaper onesWhat kind of surface do you run on? You want to go larger? Factory is pretty close to a 2.8 stadiun truck size and 2.8 Monster truck will be 1/2" to 3/4" taller. You will most likely need to change your gearing to match.
You still thereWhat kind of surface do you run on? You want to go larger? Factory is pretty close to a 2.8 stadiun truck size and 2.8 Monster truck will be 1/2" to 3/4" taller. You will most likely need to change your gearing to match.
You still there
If you drive mostly on asphalt then, you might want some street tires. No help there.I drive mostly on Asphalt but sometimes I drive off-road (mostly dirt not grass) I’m looking at these right now but I want cheaper ones
1/10 Trencher HP BELTED F/R 2.8" MT Tires MTD 12mm/14mm Blk Raid (2)
